Inkplate ESP32 upload timeout on multiple USB ports
I’m having trouble uploading to my Inkplate. I’ve confirmed the button is in the on position and COM 3 is selected in the serial port settings. I’ve tried all the different USB ports on my computer. I tested both monochrome and greyscale modes. When I press compile (successful), then push, I get this error:
A fatal error occurred: Failed to connect to ESP 32: Timed out waiting for packet header
Originally submitted via the contact form on soldered.com on 28 September 2020. Migrated to the forum for community visibility.
Did you try using the Inkplate with another computer? It’s unusual that uploads are failing across multiple USB ports. Can you send a screenshot from Windows Device Manager?
