There is a slideshow sketch in the examples. It solved my problem.
Originally submitted via the contact form on soldered.com on 24 March 2025. Migrated to the forum for community visibility.
Glad it worked out for you. We recommend uploading the examples as-they-are first and reading the comments in the code to gather all the context. The examples are designed to be used without modification initially.
Updated Inkplate documentation is in progress and should make it easier to get started. Filename and path issues are common stumbling blocks when beginning with programming.
