The serial monitor shows no readable output. I’ve attached a screenshot showing a bootloop of around 6 seconds. I’m using the Inkplate_WiFi_HTTP_Request code example from your GitHub repository.
Attachment omitted in migration: Screenshot_2022-05-28_21-55-07.png
Originally submitted via the contact form on soldered.com on 20 May 2022. Migrated to the forum for community visibility.
Change the baud rate for the serial monitor to 115200 bauds to get readable outputs.
After changing to 115200 baud, here’s the output:
22:10:01.831 -> ets Jul 29 2019 12:21:46
22:10:01.831 ->
22:10:01.831 -> rst:0x1 (POWERON_RESET),boot:0x12 ( [esp32-hal-psram.c:47] psramInit(): PSRAM enabled
22:10:08.264 -> CORRUPT HEAP: multi_heap.c:432 detected at 0x3ffd1b40
22:10:08.264 -> abort() was called at PC 0x4008f5eb on core 1
22:10:08.298 ->
22:10:08.298 -> ELF file SHA256:
22:10:08.298 ->
22:10:08.298 -> Backtrace: 0x4008b290:0x3ffcd7d0 0x4008b50d:0x3ffcd7f0 0x4008f5eb:0x3ffcd810 0x4008fbb0:0x3ffcd830 :0x3ffcd850 0x400875a6:0x3ffcd870 :0x3ffcd890 0x4000beaf:0x3ffcd8b0 0x4008c56a:0x3ffcd8d0 0x400dc9d8:0x3ffcd8f0 0x400d4247:0x3ffcd920 0x400d47b0:0x3ffcd950 0x400d1e92:0x3ffcda50 0x400d6ebe:0x3ffcda70 0x4008bdd6:0x3ffcda90
22:10:08.373 ->
22:10:08.373 -> Rebooting...
22:10:08.373 -> ets Jul 29 2019 12:21:46
22:10:08.373 ->
22:10:08.373 -> rst:0xc (SW_CPU_RESET),boot:0x12 (SPI_FAST_FLASH_BOOT)
22:10:08.373 -> configsip: 0, SPIWP:0xee
22:10:08.373 -> clk_drv:0x00,q_drv:0x00,d_drv:0x00,cs0_drv:0x00,hd_drv:0x00,wp_drv:0x00
22:10:08.373 -> mode:DIO, clock div:2
22:10:08.373 -> load:0x3fff0018,len:4
22:10:08.373 -> load:0x3fff001c,len:1100
22:10:08.373 -> load: ,len:10900
22:10:08.373 -> load: ,len:6360
22:10:08.373 -> entry 0x400806b4
22:10:09.491 -> [esp32-hal-psram.c:47] psramInit(): PSRAM enabled
22:10:15.029 -> CORRUPT HEAP: multi_heap.c:432 detected at 0x3ffd1b40
22:10:15.029 -> abort() was called at PC 0x4008f5eb on core 1
22:10:15.029 ->
22:10:15.029 -> ELF file SHA256:
22:10:15.029 ->
22:10:15.029 -> Backtrace: 0x4008b290:0x3ffcd7d0 0x4008b50d:0x3ffcd7f0 0x4008f5eb:0x3ffcd810 0x4008fbb0:0x3ffcd830 :0x3ffcd850 0x400875a6:0x3ffcd870 :0x3ffcd890 0x4000beaf:0x3ffcd8b0 0x4008c56a:0x3ffcd8d0 0x400dc9d8:0x3ffcd8f0 0x400d4247:0x3ffcd920 0x400d47b0:0x3ffcd950 0x400d1e92:0x3ffcda50 0x400d6ebe:0x3ffcda70 0x4008bdd6:0x3ffcda90
22:10:15.062 ->
22:10:15.062 -> Rebooting...
22:10:15.062 -> ets Jul 29 2019 12:21:46
22:10:15.062 ->
22:10:15.062 -> rst:0xc (SW_CPU_RESET),boot:0x12 (SPI_FAST_FLASH_BOOT)
22:10:15.062 -> configsip: 0, SPIWP:0xee
22:10:15.062 -> clk_drv:0x00,q_drv:0x00,d_drv:0x00,cs0_drv:0x00,hd_drv:0x00,wp_drv:0x00
22:10:15.062 -> mode:DIO, clock div:2
22:10:15.062 -> load:0x3fff0018,len:4
22:10:15.062 -> load:0x3fff001c,len:1100
22:10:15.095 -> load: ,len:10900
22:10:15.095 -> load: ,len:6360
22:10:15.095 -> entry 0x400806b4
22:10:16.222 -> [esp32-hal-psram.c:47] psramInit(): PSRAM enabled
22:10:21.757 -> CORRUPT HEAP: multi_heap.c:432 detected at 0x3ffd1b40
22:10:21.757 -> abort() was called at PC 0x4008f5eb on core 1
22:10:21.757 ->
22:10:21.757 -> ELF file SHA256:
22:10:21.757 ->
22:10:21.757 -> Backtrace: 0x4008b290:0x3ffcd7d0 0x4008b50d:0x3ffcd7f0 0x4008f5eb:0x3ffcd810 0x4008fbb0:0x3ffcd830 :0x3ffcd850 0x400875a6:0x3ffcd870 :0x3ffcd890 0x4000beaf:0x3ffcd8b0 0x4008c56a:0x3ffcd8d0 0x400dc9d8:0x3ffcd8f0 0x400d4247:0x3ffcd920 0x400d47b0:0x3ffcd950 0x400d1e92:0x3ffcda50 0x400d6ebe:0x3ffcda70 0x4008bdd6:0x3ffcda90
22:10:21.790 ->
22:10:21.790 -> Rebooting...
22:10:21.790 -> ets Jul 29 2019 12:21:46
22:10:21.790 ->
22:10:21.790 -> rst:0xc (SW_CPU_RESET),boot:0x12 (SPI_FAST_FLASH_BOOT)
22:10:21.790 -> configsip: 0, SPIWP:0xee
22:10:21.899 -> clk_drv:0x00,q_drv:0x00,d_drv:0x00,cs0_drv:0x00,hd_drv:0x00,wp_drv:0x00
22:10:21.899 -> mode:DIO, clock div:2
22:10:21.899 -> load:0x3fff0018,len:4
22:10:21.899 -> load:0x3fff001c,len:1100
22:10:21.899 -> load: ,len:10900
22:10:21.899 -> load: ,len:6360
22:10:21.899 -> entry 0x400806b4
22:10:22.951 -> [esp32-hal-psram.c:47] psramInit(): PSRAM enabled
22:10:28.488 -> CORRUPT HEAP: multi_heap.c:432 detected at 0x3ffd1b40
22:10:28.488 -> abort() was called at PC 0x4008f5eb on core 1
22:10:28.488 ->
22:10:28.488 -> ELF file SHA256:
22:10:28.523 ->
22:10:28.523 -> Backtrace: 0x4008b290:0x3ffcd7d0 0x4008b50d:0x3ffcd7f0 0x4008f5eb:0x3ffcd810 0x4008fbb0:0x3ffcd830 :0x3ffcd850 0x400875a6:0x3ffcd870 :0x3ffcd890 0x4000beaf:0x3ffcd8b0 0x4008c56a:0x3ffcd8d0 0x400dc9d8:0x3ffcd8f0 0x400d4247:0x3ffcd920 0x400d47b0:0x3ffcd950 0x400d1e92:0x3ffcda50 0x400d6ebe:0x3ffcda70 0x4008bdd6:0x3ffcda90
22:10:28.523 ->
22:10:28.523 -> Rebooting...
22:10:28.523 -> ets Jul 29 2019 12:21:46
The “CORRUPT HEAP: multi_heap.c:432 detected at 0x3ffd1b40” line appears to be causing the issue.
This issue is documented at Version 5.7.0 has breaking changes from 5.5.1 · Issue #145 · SolderedElectronics/Inkplate-Arduino-library · GitHub. Download the latest version of the Inkplate library and try the WiFi examples.
