Inkplate10 black and white example not displaying after upload
I have Ubuntu 22.04 with Arduino IDE connected to my Inkplate10 board. The black and white example uploads successfully - the Arduino IDE log shows no errors and the upload completes. However, the board display does not change after upload. I’ve tried toggling the power button and disconnecting/reconnecting the USB cable, but the display still doesn’t update.
The upload log:
Sketch uses 357533 bytes (11%) of program storage space. Maximum is 3145728 bytes.
Global variables use 32032 bytes (9%) of dynamic memory, leaving 295648 bytes for local variables. Maximum is 327680 bytes.
esptool.py v4.2.1
Serial port /dev/ttyUSB0
Connecting.........
Chip is ESP32-D0WD-V3 (revision 3)
Features: WiFi, BT, Dual Core, 240MHz, VRef calibration in efuse, Coding Scheme None
Crystal is 40MHz
MAC: 94:e6:86:a8:61:d0
Uploading stub…
Running stub…
Stub running…
Changing baud rate to 921600
Changed.
Configuring flash size…
Flash will be erased from to 0x00005fff…
Flash will be erased from to 0x00008fff…
Flash will be erased from 0x0000e000 to 0x0000ffff…
Flash will be erased from to 0x00067fff…
Compressed 18912 bytes to 13025…
Writing at … (100 %)
Wrote 18912 bytes (13025 compressed) at in 0.5 seconds (effective 308.6 kbit/s)…
Hash of data verified.
Compressed 3072 bytes to 119…
Wrote 3072 bytes (119 compressed) at in 0.1 seconds (effective 348.2 kbit/s)…
Compressed 8192 bytes to 47…
Writing at 0x0000e000… (100 %)
Wrote 8192 bytes (47 compressed) at 0x0000e000 in 0.1 seconds (effective 562.9 kbit/s)…
Compressed 357920 bytes to 176890…
Writing at … (9 %)
Writing at 0x00020d1f… (18 %)
Writing at 0x00031ff1… (27 %)
Writing at 0x0003749c… (36 %)
Writing at 0x0003ca8c… (45 %)
Writing at 0x00041fa0… (54 %)
Writing at 0x000473fd… (63 %)
Writing at 0x0004fa62… (72 %)
Writing at 0x00057ddb… (81 %)
Writing at 0x0005d7ad… (90 %)
Writing at 0x00062cae… (100 %)
Wrote 357920 bytes (176890 compressed) at in 3.3 seconds (effective 868.0 kbit/s)…
Leaving…
Hard resetting via RTS pin…
Originally submitted via email support on 31 August 2023. Migrated to the forum for community visibility.
The upload log is fine and the ESP32 on the Inkplate board has received the new code.
The issue is likely the board definition in Arduino IDE. There are differences between the e-Radionica Inkplate10 and the Soldered Inkplate10 that make code compiled for one version not work for the other. Check which board version you have by looking at the PCB color: blue PCB means e-Radionica, purple PCB means Soldered. The identification guide is here: Inkplate Arduino — Inkplate docs documentation
Try with the correct board definition in Arduino IDE. The basic black and white or grayscale examples should refresh the screen once you’re using the matching definition.
That was it - I was using the Soldered board definition, but I have the e-Radionica board. The example works now.
