Inkplate10 examples upload successfully but screen doesn't update
I went through the Arduino setup steps and got everything configured for Inkplate10. When I run any of the examples, nothing happens. The screen still shows the factory image, and there are no error messages. The Arduino IDE output looks normal - sketch uploads successfully at 416136 bytes with no errors reported.
Originally submitted via email support on 16 April 2023. Migrated to the forum for community visibility.
Check that you’re using the newest Inkplate library and board definition. Note that there are 2 versions of Inkplate10 boards. If you have the newer version, you need to select “Soldered Inkplate10” in the Arduino boards menu before uploading.
