L298N motor driver 101277 pin position and mounting hole dimensions
I need to mount the L298N motor driver (component 101277) on a custom PCB. I’m looking for spatial information about the pin positions for EN1&2, IN1-4, and the power supply block. Specifically, I need the dimensions for both pin rows measured from a reference corner, and the positions of the mounting holes in the corners.
Originally submitted via email support on 2 September 2025. Migrated to the forum for community visibility.
A 3D model of the L298N motor driver is available for reference: L298N Motor Driver - Download Free 3D model by peddintiudaykiran176 [4226c9a] - Sketchfab
You can use this model to measure the pin positions and mounting hole locations yourself.
