I have an elevator project using a Maxon 12V DC motor with a gearbox connected through an L298N to Arduino. The problem is that the motor loses power—at a certain height, the voltage drops to 0.8V. I tried connecting a 19V power supply to get 15V at the motor due to the voltage drop across the driver itself, but the same thing happens. When I connect that same motor directly to a 12V power supply, everything works normally. I’m not sure if the problem is in the L298N, because according to the datasheet the motor doesn’t exceed 2A at startup, which is within the L298N’s rating. Would your DRV8484 driver work better than my L298N?
Pozdrav, Imam projekt dizala i koristim maxon 12v dc motor s reduktorom povezan preko L298N na arduino,problem mi se dogada da motor izgubi snagu,tj.napon na nekoj odredenoj visini padne na 0.8 V.,probao sam cak i spojiti izvor napajanja 19V da na motoru dobijem 15 v,zbog pada napona na samom driveru,medutim ista je situacija. Kada taj isti motor spojim direktno na izvor napajanja 12v sve radi normalno,sad mi nije jasno jel problem u L298n,jer po datashetu motor pri pokretanju ne prelazi 2A koliko L298N moze dati? Zanima me jel bi vas driver drv8484 radio bolje od ovog mog L298N?
Hvala,lp
Originally submitted via email support on 6 July 2023. Migrated to the forum for community visibility.
