LED Dice Kit LEDs not lighting and sensors unresponsive
I received several LED Dice kits for a soldering workshop and have been unable to get them to work. The battery tested good at 3.1 volts.
Testing one of the force sensors shows the same resistance both while shaking and while holding still.
Shortinig across the pins of the shake sensor results in no change.
The LEDs have either 0.8 volts across them or 0 volts - neither is enough to light up the LED.
What troubleshooting steps can I try?
Originally submitted via email support on 2 October 2025. Migrated to the forum for community visibility.
The kits have a pre-programmed ATtiny microcontroller on them doing the display logic. The voltages you’re measuring are unusual. My suspicion is either incorrect resistor values in the kit or that the microcontroller isn’t programmed or is malfunctioning.
Could you send a high quality picture of the assembled kit? Also, how many have you assembled from the package to test?
Files are attached. Looking closer, there are three empty pins between R2 and L2, but I don’t have a part to put in there. I’ve only assembled one so far.
Attachment omitted in migration: 20251003_113522.jpg
Attachment omitted in migration: 20251003_113530.jpg
Attachment omitted in migration: 20251003_113541.jpg
Every single kit gets pre-programmed and it’s possible the one you assembled has some fault. Please assemble one more from your kit and let me know how it works out. If it still doesn’t work, I can send you replacements.
