LED Dice Kit: soldering the vibration sensor and empty pads
I’m trying to solder the components for the LED Dice kit, but I’m not sure how to solder the black component with one thin and one thick leg. Also, on the left side of the board there are 3 holes but no component to go there. From the gif on your website it looks like I should just apply solder to close the circuit, but I’m not certain.
The top image has parts marked that I’m unsure how to connect. It would also be good if you could update the instructions for this soldering kit, because from what I can see this is a completely different design from the one shown in the existing guide.
Poštovani, Trenutno pokušavam zalemiti komponente za LED kocku, no nisam siguran kako zalemiti crnu komponentu s jednom tanjom i jednom debljom nožicom.
Također na lijevoj strani pločice su 3 rupice no nema komponente koje bi išla tamo. Iz gifa na vašoj stranici se da zaključiti da bi trebalo samo staviti lema kako bi se zatvorio strujni krug, no nisam siguran da li je to tako.
Gornja slika ima naznačene dijelove za koje nisam siguran kako spojiti.
Također bilo bi dobro da možda updateate instrukcije za ovaj set za lemljenje. Jer koliko vidim ovo je sasvim drugačiji dizajn https://soldered.com/hr/learn/kockica-od-leda-ili-kako-lemiti/
Attachment omitted in migration: 1000009130.jpg
Originally submitted via email support on 14 December 2024. Migrated to the forum for community visibility.
The 3 holes are programming pins for the microcontroller on the board, so you don’t need to solder anything to them. These holes are populated because this specific LED Dice unit was used for our own testing and development.
S2 is the vibration sensor SW-18020P positioned right below in the image. It has no polarity (it works like a switch that closes the circuit when it detects movement). When soldered, it simply bends toward the board as shown in the gif.
ovdje sam za pomoć :slight_smile: 3 nožice su naime pinovi za programiranje mikroupravljača koji je na pločici, tako da na njih ne treba ništa zalemiti. Tu su samo te rupe popunjene jer taj specifični LED Dice je bio naš koji smo mi koristili za testiranje i razvoj. Isprike ako je izazvalo pomutnju.
S2 je točno ovaj “Vibration sensor SW-18020P” koji je stavljen odmah ispod na slici i nema polaritet (ponaša se kao prekidač koji zatvara strujni krug kad detektira ‘mrdanje’). Kad se zalemi, on se samo savije prema pločici kao što se vidi na tom GIF-u.
Nadam se da ovo pomaže dovršiti projekt :slight_smile:
