What is the inner diameter of this LED ring?
zanima me koji je unutarnji promjer ovog LED kruga? Soldered: Open-Source Electronics, Boards, Sensors & Modules – Soldered Electronics
Originally submitted via email support on 14 May 2020. Migrated to the forum for community visibility.
The inner diameter of the LED ring is approximately 26mm.
hvala Vam na upitu.
Unutarnji promjer LED kruga je cca 26mm.
Do you have versions with a larger inner diameter?
Imate li možda sa većim unutarnjim promjerom?
Versions with larger inner diameters are available with 24 and 36 LEDs.
24 LED: approximately 53mm
36 LED: approximately 84mm
hvala Vam na upitu.
S većim unutarnjim promjerom su verzije sa 24 i 36 LED dioda.
24 LED: cca 53mm
36 LED: cca 84mm
