Li-ion battery 2100mAh 3.7V replacement with 93mm×68mm×3mm dimensions
I need a replacement battery with these dimensions: height 93mm, width 68mm, thickness 3mm. The current battery is 2100mAh at 3.7V. Can you suggest a compatible battery?
nastavno na telefonski razgovor. Radi se o bateriji priloženo, dimenzije su: V:93mm, Š:68mm.
2100mAh te 3.7 V.
Molim Vas da mi pošaljete link neke baterije koja bi mogla odgovarati dimenzijski.
Attachment omitted in migration: 1.jfif
Originally submitted via email support on 16 February 2022. Migrated to the forum for community visibility.
To help you find the right battery, could you provide the third dimension - the thickness? How thick can the battery be for your enclosure to close properly?
hvala Vam na upitu. Možete li ikako dati i treću dimenziju (debljinu)? Koliko “debela” baterija smije biti kako biste mogli zatvoriti kućište?
The thickness is 3mm.
3mm je debljina
With those specifications, we have limited options. For your exact dimensions (93mm × 68mm × 3mm), we have a 70mAh 3.7V battery available. We also stock a 1200mAh battery, but it is 5mm thick. For the 2100mAh capacity, the available battery is 5mm thick and will not fit in the space of your original battery.
hvala Vam na brzom odgovoru. Nažalost, u tim parametrima imamo samo sljedeće:
U opisu artikla navedene su dimenzije svake baterije.
Sljedeća baterija koju imamo bi bila: https://e-radionica.com/hr/li-ion-baterija-1200mah.html kojoj je debljina 5mm, a za 2100mAh sam uvjeren da ne može stati na mjesto stare baterije: https://e-radionica.com/hr/li-ion-baterija-2100mah.html
