Li-ion Battery Charger Board outputs no voltage when powered from battery
I’m using your Li-ion battery charger board with protection. I connected a microcontroller to it, but it only works when a USB cable is connected to the charger board. When it should be drawing power from the battery, there’s no voltage output.
My connections are: Gnd connected to Out- and Vcc connected to Out+. The battery is connected to Bat- and Bat+.
When measuring voltage, I accidentally touched Bat- and Out- together, and then the microcontroller worked.
My questions are: can the microcontroller be connected to Bat- instead of Out-, and do you have any examples of how to connect microcontrollers to the charger board?
Bio sam kupio vašu pločicu za punjenje Li-Ion baterija sa zaštitom.
Spojio sam mikrokontroler na nju, ali radi samo kada je u pločicu za punjenje spojen usb kabel.
Kada bi trebala uzimati struju iz baterije, nema napona.
Na mikrokontroler Gnd je spojen na Out- i Vcc je spojen na Out+.
Baterija je spojena na Bat- i Bat+.
Dok sam mjerio napon sličajno sam taknuo Bat- i Out-. Tada je mikrokontroler proradio.
Moje pitanje je da li se može mikrokontroler spojiti na Bat- umjesto na Out- i da li imate neke primjere kako spajati mikrokontrolere s pločicom za punjenje?
Originally submitted via email support on 11 January 2023. Migrated to the forum for community visibility.
Can you share photos of how you connected everything or send a schematic showing how you connected the charger board with the microcontroller?
možete li slikati kako ste to sve spojili ili poslati shemu po kojoj ste spojili pločicu s mikrokontrolerom?
I apologize for the messy wiring—this is my first soldering project. I’ve attached photos of the connections and a schematic. The schematic is from: Tracker Schematics - SlimeVR Docs
Ispričavam se zbog nereda pri spajanju. To mi je prvi projekt s lemljenjem.
U prilogu su slike spojeva i shema. Shema je nađena na sljedećoj stranici: Tracker Schematics - SlimeVR Docs
Attachment omitted in migration: 20230112_135824.jpg
Attachment omitted in migration: 20230112_135844.jpg
Attachment omitted in migration: 20230112_135918.jpg
Attachment omitted in migration: Screenshot_20230112-140017_Chrome.jpg
To answer your earlier question: the microcontroller cannot be connected to BAT- instead of OUT- because you would be bypassing the battery protection. You can do it, but at your own risk.
Regarding your wiring schematic, try removing the two 1N5817 diodes that you connected on the power supply side, and change the switch so that instead of switching the ground, it switches the power supply—that is, the 5V. Try this and let us know if it works.
na prijašnje pitanje sam zaboravio odgovoriti, mikrokontroler se ne može spojiti na BAT- umjesto na OUT- jer tako zaobilazite zaštitu za bateriju. Možete to spojiti, ali na svoju odgovornost.
Što se tiče sheme spajanja, možete li probati maknuti dvije diode 1N5817 koje ste spojili kod napajanja, te switch koji sada prekida masu prebaciti da prekida napajanje odnosno 5V. Probajte ovo pa javite hoće li Vam onda raditi.
