I purchased a battery from you with the following specifications: 10000 mAh at 3.7V. I need to be able to charge this battery using a USB cable. What do I need to buy from you?
Kupio sam kod vas bateriju sa sljedećim tehnički podacima: 10 000 mAh na 3.7 V. Trebam za navedenu bateriju da ju mogu puniti pomoću USB kabla. Što trebam kod vas kupiti? Hvala, LP.
Originally submitted via email support on 9 March 2022. Migrated to the forum for community visibility.
To charge a li-ion battery with a JST connector, you need a li-ion battery charger with that connector. We previously offered chargers at Soldered: Open-Source Electronics, Boards, Sensors & Modules – Soldered Electronics and Soldered: Open-Source Electronics, Boards, Sensors & Modules – Soldered Electronics. These are currently not in stock, but as we are in a rebranding process, we have designed new versions of the above chargers with completely identical functionality. They are not yet officially available, but we are able to provide you with an offer if you are interested.
hvala Vam na upitu. Za punjenje li-ion baterije s JST konektorom, potreban Vam je punjač za li-ion baterije s takvim konektorom.
I need a charger for charging the battery via USB with the specifications 10000 mAh at 3.7V.
dr. sc. [name removed] Zimmer Sveučilište Josipa [name removed] u Osijeku Fakultet agrobiotehničkih znanosti Osijek Zavod za poljoprivrednu tehniku i obnovljive izvore energije www.strojevi.com.hr
I apologize for the confusion. The question concerns a charger for li-ion batteries with the specifications you requested. We have them available both with and without protection.
