Li-ion charger with protection output pins location
I purchased a charger kit from you previously and have some questions: 1. Do you still have this battery/charger and what is the current price? 2. Do you have this charger with a USB TYPE-C connector instead of USB MICRO, and if so, what is the price? 3. Can you help me identify where the positive and negative current output terminals are on the charger I have, as I need to power a circuit with it? I bought this kit to assemble a device and will need additional units in the near future, so it’s important that this remains available from you. I’m also building a housing around the charger and battery you sold me, so consistency is critical. I’m not familiar with electronics, so I’d appreciate your help identifying the output terminals rather than having to find someone locally to assist.
Attachment omitted in migration: IMG_20230401_181242_629~2.jpg
Originally submitted via email support on 1 April 2023. Migrated to the forum for community visibility.
That battery is no longer available. You can see the current battery offerings and prices at https://soldered.com/hr/kategorije/napajanja-baterije/baterije/litijske-punjive/
The Li-ion charger with protection is available and comes with a USB-C connector. The dimensions of the new charger differ from the previous model and measure 38x22mm, which you can see on the product page: Li-Ion Punjač s zaštitom - sigurno rješenje za punjenje – Soldered Electronics
Connect your desired circuit to the OUT+ and OUT- pins on the charger.
Dimenzije novoga punjača su nešto drugačije od prethodnog punjača i iznose 38x22mm što možete vidjeti na stranici proizvoda. Li-Ion Punjač s zaštitom - sigurno rješenje za punjenje – Soldered Electronics Željeni sklop spajate na OUT+ i OUT - pinove punjača. Ako je potrebno dodatno pojašnjenje oko rada i spajanja slobodno nas kontaktirajte.
