I’m interested in purchasing a simple light sensor like shown in the product image. Can I use this sensor as a photocell to turn a light on and off? I have a lamp I’d like to automate so it turns on in the dark and off during the day. The lamp operates at 3 V (powered by 2x1.5V batteries), and I’ve installed an LED as the light source. Can this sensor work independently, just connected in a circuit with the battery and lamp, or do I need additional components?
Dobar dan! Zainteresiran sam za kupnju jednostavnog senzora svjetlosti kao na slici. Dali je moguće taj senzor koristiti kao fotoćeliju za paljenje i gašenje rasvjete? Imam lampu koju bih želio automatizirati da se u mraku upali a po danu ugasi. Radni napon lampe je 3 V (baterije 2x1.5V), a kao izvor svjetla u lampi sam ugradio LED diodu. I zanima me dali ovaj senzor može raditi samostalno samo da se poveže u strujnom krugu baterije i lampe ili je potrebno ugraditi još neke dodatne komponente? Hvala
Attachment omitted in migration: Screenshot_20240313-165938.png
Originally submitted via email support on 13 March 2024. Migrated to the forum for community visibility.
You’ll need an additional PMOS (P-channel MOSFET) in this circuit. The PMOS will turn off the circuit when the output is HIGH (the output from the D0 pin on the breakout), which happens when there’s light, and turn on the circuit when the output is LOW (in darkness). The advantage of this breakout is that you can set the light level threshold for when the output goes high/low using the potentiometer already on the board.
Connect D0 to the MOSFET gate, and your load (the light) goes to the MOSFET drain.
For details on using a MOSFET as a switch, see: https://www.electronics-tutorials.ws/transistor/tran_7.html
razumijem upit. U tom strujnom krugu ti treba još dodatan MOSFET, specifičnije PMOS. PMOS će ugasiti strujni krug ako je izlaz HIGH (što je izlaz sa D0 pina na tom breakoutu), što će biti kada svjetla ima, a upaliti strujni krug ako je izlaz LOW (ako je mrak). Ono što je super kod ovog breakouta je to što možeš odrediti razinu svjetla kad je output high/low sa potenciometrom koji je već na pločici.
D0 se spaja na gate MOSFET-a, svjetlo je na LOAD.
Provjeri ovu stranicu koja opisuje kako koristiti MOSFET kao prekidač: https://www.electronics-tutorials.ws/transistor/tran_7.html
Mislim da bi ovo trebalo raditi OK
Ako imaš neka dodatna pitanja slobodno javi
Thank you for the explanation. Since I have no experience working with electronic components, could you provide an explanation of how to connect the MOSFET and light sensor, and at which points the battery supply connects and where the connections go to the LED diodes? I apologize for asking, but I don’t have electronics experience and I don’t understand those MOSFET diagrams.
Odlično! Hvala vam na ovom objašnjenju. Pošto nemam iskustva u radu s elektroničkim komponentama, mogu li dobiti objašnjenje kako povezati MOSFET i svjetlosni senzor, i na kojim mjestima se povezuje dovod sa baterija, a na kojim mjestima se povezuje odvod prema LED diodama. Oprostite što vas gnjavim ali nemam iskustva u radu s elektronikom i baš ne razumijem one nacrte o MOSFET-u
Although this project looks simple on the surface, it does require basic electronics knowledge and schematic understanding, which might make it challenging for a beginner. We don’t have a product in our range that would make this simpler.
If you still want to try connecting this, here’s a quick guide, but keep in mind that with limited electronics knowledge, troubleshooting might be difficult:
- Gate connects to D0 of the sensor
- GND of the sensor connects to GND
- VCC of the sensor connects to + of the battery
- of the load connects to Drain
- − of the load connects to GND
- of the battery connects to Source
- − of the battery connects to GND
šaljem sliku kako to izgleda fizički na samom MOSFETU:
Iako je ovaj projekt naizgled jednostavan, zahtjeva osnovno poznavanje elektronike i spajanje sheme, i onda možda kao takav je malo pre jak za početnika. Ne postoji proizvod u našem asortimanu s kojim bi se moglo to napraviti jednostavnije.
Ako još uvijek želiš probati spojiti ovo, evo kratke upute, samo imaj na umu da s ograničenim razumijevanjem bi možda bilo teško troubleshootati.
Gate se spaja na D0 od senora GND od senzora se spaja na GND VCC od senzora se spaja na + od baterija + od trošila se spaja na Drain - od trošila se spaja na GND + od baterije se spaja na source - od baterije se spaja na GND
nadam se da je ovo korisno
I think I understand now. Here’s my hand-drawn schematic. It’s not professionally drawn, but I think that’s it.
Mislim da sam sve shvatio, evo moje ručno nacrtane sheme. Nije stručno nacrtano ali mislim da je to to
Attachment omitted in migration: IMG_20240314_165237824.jpg
Your schematic is good. GND is common throughout the entire circuit. When you choose a PMOS, make sure it’s a ‘logic level’ PMOS so it can turn on at 2V—this will properly switch the circuit. Check the datasheet characteristics of your PMOS for this.
I should mention that since we don’t have this exact load in our testing setup, we can’t verify this connection method, so there may be additional troubleshooting needed.
Pozdrav, shema je dobra, GND je zajednički u cijelom strujnom krugu. Kad uzimaš PMOS, samo pazi da je ‘logic level’ PMOS, da se može upaliti na već 2V, tako će upaliti strujni krug. Za to, pogledaj karakteristike tog PMOS-a.
Htio bi još samo jednom napomenuti da kako nemamo točno to trošilo kod sebe ne možemo testirati taj prijedlog spajanja i postoji mogućnost da će biti još troubleshootanja.
I’m still unclear about GND. I looked it up online and it’s described as ground/earth. Does this mean I need to physically ground all the equipment?
Jedino taj GND mi nije jasno. Pogledao sam na googleu što znači GND i tamo je navedeno kao uzemljenje. Znači li to da trebam uzemljiti svu opremu?
No, you don’t need to physically ground the equipment. GND is simply a common ‘point’ between all the circuits. Everything connected to GND is actually connected at the same point. Look at your schematic: the GND from the sensor, the − from the battery, and the − from the load are all actually at the same point in terms of the circuit.
Pozdrav, ne nije potrebno uzemljiti opremu, GND je samo zajednička ‘točka’ između svih strujnih krugova. Sve što je spojeno na GND je zapravo spojeno u istoj točki. Pogledaj na tvojoj shemi kako je GND od senzora, - od baterije i - od trošila sve u zapravo istoj točki (što se tiče sheme).
Nema na čemu na pomoći! Nadam se da će proći dobro i da će raditi OK
