I’m interested in your LIN MASTER breakout board.
I have one question about the item description which states: “LIN MASTER serves as a gateway to CAN-bus”. Could you please explain how the conversion from LIN to CAN works?
Originally submitted via email support on 15 November 2021. Migrated to the forum for community visibility.
The description is accurate, but it requires a microcontroller, which wasn’t clearly stated.
To use LIN MASTER as a gateway to CAN-bus, you need to:
- Connect the LIN breakout to a microcontroller
- The microcontroller reads data from the LIN breakout
- Send that data to CAN using a CAN breakout
The data conversion from the LIN network to the CAN network happens in the microcontroller. You cannot convert between LIN and CAN networks without a microcontroller to perform the conversion.
