Lipo akku parallel schalten
Hello,
I have developed a circuit board that is powered by a rechargeable battery. The device needs to run continuously throughout the year. For this purpose, I would like to connect two of your batteries ( Li-Po-Akku 10000 mAh, 3,7 V - langlebig und sicher – Soldered Electronics ) in parallel.
Before connecting them, I plan to bring both batteries to the same voltage level to prevent large equalization currents.
By connecting them in parallel, I can double the capacity. They will remain connected during charging. From a technical standpoint, I do not believe I need cell monitoring, as the parallel configuration ensures that the current is always balanced between the two batteries.
What is your take on this?
Best regards,
Hallo,
ich habe eine Platine entwickelt, welche mit einem Akku betrieben wird. Das Gerät muss das ganze Jahr über durchlaufen. Dazu möchte ich gerne zwei von euren Akkus ( Li-Po-Akku 10000 mAh, 3,7 V - langlebig und sicher – Soldered Electronics ) parallel schalten.
Ich würde dazu beide vor dem verbinden auf die gleiche Spannung bringen, damit es keine starken Ausgleichsströme gibt.
Durch eine paralleles Verbinden kann ich die Kapazität verdoppeln. Bei Laden sollen sie verbunden bleiben. Aus technischer Sicht brauche ich dafür keine Zellüberwachung, da sich durch die parallele Schaltung der Strom immer ausgleicht in beiden Akkus.
Wie euere Meinung dazu?
Mit freundlichen Grüßen
Hi,
Thank you for the details. Yes, connecting the two batteries in parallel is fine. In a parallel connection the voltage of both batteries rises and falls together, and the capacity adds up.
Matching the voltages before connecting is good practice, but I’d keep a few things in mind. Parallel packs share current, yet that doesn’t guarantee they age evenly or that one won’t develop an internal fault unnoticed. Since the device runs all year and stays connected while charging, I’d at least add a fuse or protection per pack and verify the charger handles double the capacity safely. Also check that both cells are the same model and age, since mismatched internal resistance can cause uneven loading over long periods. Worth confirming with the manufacturer too.
Lucas makes a fair point about matching age and model, not just voltage. Two 10000 mAh packs bought at different times can have quite different internal resistance, and in a year-long always-on setup that drift shows up as one pack doing most of the work. Per-pack fusing is cheap insurance too. I’d also want to know how the charger terminates, since doubling capacity could mean it takes twice as long or stops early depending on how it detects full charge. Same model, same batch, and a quick check of the charge profile are worth the effort before committing.
