LOAD-CELL HX711 BOARD quality standards and version comparison
I’m evaluating the LOAD-CELL HX711 BOARD WITH EASYC for a bench test of a medical device. Does your quality management system include ISO standards? Also, which would you recommend: the LOAD-CELL HX711 BOARD WITH EASYC or the regular LOAD-CELL AMPLIFIER HX711 BOARD?
Originally submitted via email support on 7 March 2024. Migrated to the forum for community visibility.
We have a quality management system where each product gets tested, but it’s not under ISO standards. The board itself has a lower risk of failure since it’s essentially a breakout for the HX711 chip which does all the work.
The board with easyC lets you get data from the load cell over easyC (i2c) and connect directly to a Dasduino board using an easyC cable. If you have a different microcontroller without an easyC, qwiic, or stemma QT port, the regular version is recommended. The regular version is also more responsive and faster at reading data from the HX711. For your application, I’d personally suggest the regular version for the quicker responsiveness.
We also have load cells compatible with this breakout, and the Arduino library includes a sketch to help you easily calibrate it.
