Logic Level Converter for 2.8 TFT SPI display
Can these logic level converters be used with a 2.8 inch TFT SPI display?
Pretvarač logičkih razina – Soldered Electronics Hvala,lp
Originally submitted via email support on 13 January 2025. Migrated to the forum for community visibility.
It depends on the SPI communication frequency. They can be used with a TFT if the display can operate at 4 or 8 MHz SPI - that should work OK. For anything faster than that, you would need a high speed converter.
ovisno o frekvenciji SPI komunikacije mogu se koristiti za tft. Ako zalson može raditi na 4 ili 8 MHz SPI to bi trebalo biti OK ali za išta brže od toga tražio bi neki high speed konverter.
