I’ve spent weeks trying to get these MCP2518FD breakout boards to work without success. I tried:
– Two different Linux kernel versions (6.6 and 6.12 series) with kernel debugging
– Custom test driver
– Low-level SPI with BusPirate 3.6
– Oscilloscope and logic analyzer examination
– Micro-controller firmware (RP2040) from GitHub - kentindell/canis-can-sdk: Canis Labs CAN SDK · GitHub
– Desoldered one MCP2518FD from a board and verified the board itself is OK
None of these approaches worked. The board never responds on the SPI bus.
I decapped the controller I desoldered and found something suspicious: approximately 80% of the die appears to be occupied by a ROM. Have you received other customer reports about problems with this board? How do you test the boards you sell? I can provide photos of the die and packaging.
Originally submitted via email support on 29 August 2025. Migrated to the forum for community visibility.
Photo of the decapped MCP2518FD die showing what appears to be a mask ROM occupying most of the die area.
Barcode from the board packaging.
We’ve tested this exact breakout from our warehouse and confirmed receiving and transmitting work correctly.
Several things to check:
The JP1 jumper must be soldered to connect the termination resistors on the endpoint transceiver nodes. This should be added to the documentation.
Test using our library with a MCU: GitHub - SolderedElectronics/Soldered-CAN-Bus-Breakout-MCP2518-Arduino-Library: CAN Bus Breakout with MCP2518 Soldered Arduino Library · GitHub
Some boards may need a 470uF capacitor added between the VCC and GND pins of the transceiver to stabilize the input, though the probability of all 6 units having this issue is very low.
Refer to the documentation for hookup details: CAN Transciever MCP2518 - Getting started and Initialization | Soldered Documentation
We haven’t had these kinds of complaints with this breakout before. A tester device for validation is currently in development. We can send tested units for comparison if needed.
Attachment omitted in migration: MCP2518.mp4
