MCP2518FD on Jetson Orin Nano: no CAN FD transmission with 4 modules on 2 SPI buses
I’m trying to connect 4 MCP2518FD modules to 2 SPI buses on a Jetson Orin Nano. All 4 modules initialize correctly. However, I cannot test internal loopback. When I run:
sudo ip link set can1 type can bitrate 500000 dbitrate 1000000 loopback on fd on
cansend and candump do not send or receive any data.
My device tree configuration includes:
spi@3210000 {
  compatible = "nvidia,tegra210-spi\0nvidia,tegra114-spi";
  reg = ;
  interrupts = ;
  #address-cells = ;
  #size-cells = ;
  clocks = ;
  assigned-clocks = ;
  assigned-clock-parents = ;
  clock-names = "spi";
  iommus = ;
  resets = ;
  reset-names = "spi";
  dmas = ;
  dma-names = "rx\0tx";
  dma-coherent;
  status = "okay";
  can_clock: ;
  prod-settings {
    #prod-cells = ;
  spi@0 {
    compatible = "microchip,mcp251xfd";
    reg = ;
    spi-max-frequency = ;
    pinctrl-names = "default";
    pinctrl-0 = ;
    interrupt-parent = ;
    interrupts = ;
    vdd-supply = ;
    xceiver-supply = ;
    clocks = ;
  spi@1 {
    reg = ;
    pinctrl-0 = ;
    interrupts = ;
    vdd-supply = ;
    xceiver-supply = ;
    clocks = ;
Attachment omitted in migration: Picture1.png
Originally submitted via the contact form on soldered.com on 16 May 2025. Migrated to the forum for community visibility.
Your setup with the Jetson Orin Nano and MCP2518FD modules is outside of what can be directly tested, but here are several checks that may help:
Interrupt Pin Configuration: Double-check that the interrupt pins specified in your device tree (can0_int_pin, can1_int_pin) are correctly mapped and exported in your system. If these GPIOs are misconfigured or not set as inputs, the kernel driver may never register incoming frames.
SPI Communication Check: Since all modules initialize, SPI likely works, but to be certain, try using dmesg after bringing interfaces up to catch any SPI-related driver errors.
Loopback Mode Issue: The fact that cansend and candump show no activity even in loopback mode suggests a potential driver or interrupt issue, rather than a CAN bus problem. Internal loopback does not require physical wiring, so it should work if the driver is functioning.
CAN Tools Compatibility: Ensure you are using a version of iproute2 and can-utils that supports CAN FD and internal loopback correctly. Older versions may not behave reliably with MCP2518FD.
Device Tree Overlays: Although you have included a custom device tree, make sure no conflicting overlays are applied via /boot/extlinux/extlinux.conf or equivalent on Jetson. Conflicting settings can interfere silently.
Testing With Arduino (If Available): If you can test one of the modules using the Arduino library and a known-good CAN transceiver setup, it could help isolate whether the issue is hardware, wiring, or configuration on the Jetson side.
