Is it possible to program with the MFRC-522 RFID 13.56MHz reader?
da li je moguće i programirati sa čitaćem MFRC-522 RFID 13.56MHZ ČITAČ?
– Lijep pozdrav,
Originally submitted via email support on 10 October 2022. Migrated to the forum for community visibility.
To program with the MFRC-522 RFID reader, you need to use a development board that has a microcontroller, such as Dasduino CORE. Instructions on how to connect and program the RFID Reader MFRC-522 can be found in the documentation. If you want to program tags or cards, you can do so, but you must have the appropriate type of tag or card.
kako bi ste mogli programirati RFID READER MFRC-522 potrebno je koristiti neku razvojnu ploču koja na sebi ima mikroupravljač kao što je Dasduino CORE https://e-radionica.com/hr/dasduino-core-zenski-headeri.html.
Upute, odnosno kako možete spojiti i programirati RFID Reader MFRC-5222 se nalaze na linku https://e-radionica.com/hr/blog/2018/07/26/kkm-rfid-reader-mfrc-522/.
Ako mislite možete li programirati tagove ili kartice, možete ali morate imati takvu vrstu taga ili kartice.
