MINI PUMPA ZA VODU - outlet tube diameter and additional parts
I’m interested in the MINI PUMPA ZA VODU for submerging in barrels to make garden watering easier. What other parts are available for use with the pump? Also, what is the diameter of the outlet tube that the hose connects to?
Kupila bi KKM: MINI PUMPA ZA VODU za potapanje u bačve kako bi lakše zalijevali vrt.
Da li se kod vas mogu kupiti i ostali dijelovi za korištenje pumpe?
I koji je promjer cjevčice na koje se spaja crijevo.
Originally submitted via email support on 9 July 2020. Migrated to the forum for community visibility.
The outlet tube dimensions are:
External diameter: 7.5mm
Internal diameter: 4.7mm
For this system, you only need a Croduino and a switch according to the product documentation. Both are available in our store.
Switch: https://e-radionica.com/hr/prekidac-spdt-tht.html
Croduino Basic3: Soldered: Open-Source Electronics, Boards, Sensors & Modules – Soldered Electronics
hvala Vam na upitu. Vanjski promjer cjevčice za odvod: 7.5mm Unutarnji promjer cjevčice za odvod: 4.7mm Prema KKM-u, za takav sustav potrebni su sam Croduino i prekidač. Prekidač: https://e-radionica.com/hr/prekidac-spdt-tht.html Croduino Basic3: Soldered: Open-Source Electronics, Boards, Sensors & Modules – Soldered Electronics Na sva tehnička pitanja odgovaramo preko našeg foruma: http://forum.e-radionica.com/hr/index.php
