miniNOVA maximum input voltage and power supply options
I’m looking for something like miniNOVA but with input of at least 12V that already has its own regulation. Do you have anything like that? I recall that one of the Croduino versions could handle up to 30V.
pozdrav, tražim nešto poput miniNova ali da je input barem 12V ( da već ima svoju regulaciju ), da li imate nešto takvo, jer koliko se sjećam jedna od verzija Croduina je podnosila do 30V
Originally submitted via email support on 2 October 2017. Migrated to the forum for community visibility.
The miniNOVA has a maximum input voltage of 15V, so it will work with 12V but will be quite inefficient and will heat up significantly.
You can use a much more efficient step-down module: Step-down modul s LM2596S – Soldered Electronics which will step 12V down to 3.3V with 90% efficiency.
za miniNOVA max. ulazni napon je 15V - tako da će ići, ali će biti dosta neefikasno i zagrijavat će se.
Možete koristiti puno efikasniji modul za spuštanje napona: Step-down modul s LM2596S – Soldered Electronics
on će 12V spustiti na 3.3V s 90% efikasnosti.
