I’m building a kit for a broadcast setup that will be mounted in a server rack, similar to patch panels with Neutrik D-series connectors. I want to integrate Inkplate 5 so it can display remotely updated information on the back panel. We typically laser cut sheet metal blanks to fit our components. Can you help me mount the Inkplate 5 in a similar way? Could the 3D printed cases be modified for this purpose?
Originally submitted via email support on 2 October 2025. Migrated to the forum for community visibility.
The Inkplate 5V2 3D printable case is available as .STL files in the repository. The case can be mounted vertically or horizontally.
Mounting specifications:
- Horizontal orientation: mounting slots are 45mm apart
- Vertical orientation: mounting slots are 30mm apart
- Slot depth: approximately 3mm
Use screws with thinner heads so they fit snugly inside the slots.
The case has a space on the back designed to hang by a screw head or nail. You can fully modify the .STL file to create a custom mounting solution tailored to your specific rack requirements.
