MPS20N0040D-S pressure sensor connection to ADC
I need to use the pressure sensor MPS20N0040D-S, but the datasheet I found has diagrams that are too pixelated to read clearly. Is there better documentation available? Which output pins should connect to an ADC, and do I need an external amplifier?
Originally submitted via email support on 4 April 2024. Migrated to the forum for community visibility.
Can you provide the SKU (a 6-digit number like 333215) or order information so I can identify the exact product and assist you better?
I purchased this sensor from a different reseller without documentation. I found the datasheet at https://softroboticstoolkit.com/files/sorotoolkit/files/mps20n0040d-s_datasheet.pdf, but the graphics are very low resolution. I don’t have the SKU, but I was directed to contact you for support.
Attachment omitted in migration: Pressure_Sensor.pdf
This product is from our older product line when we were called e-Radionica, and it no longer has an equivalent in our current product range. The datasheet you found is the best available documentation. Here’s an example circuit that may help: https://bc-robotics.com/wp-content/uploads/2020/09/MPS20N0040D-2.jpg from https://bc-robotics.com/shop/pressure-sensor-2/
