I have multiple MQ-Sensors and want to use them with Dasduino Core, Dasduino LITE and Nula Max boards. According to the sensor documentation it needs 5V. Do I have to connect the 5V pin additionally to the board (not only easyC) as shown in your documentation?
Originally submitted via email support on 17 January 2026. Migrated to the forum for community visibility.
You do not have to connect the 5V pin, as the sensor breakout itself has a voltage regulator and boost to 5V. The pins you are referring to on the breakout is used for a UPDI programmer, which we use when programming the onboard ATTiny during assembly. It can come in handy if you are daisy chaining multiple MQ sensors, as that can cause a voltage drop on that line, so the 5V pin can be used to provide a stable voltage to those sensors.
