I plan to use the Ozone sensor MQ131 breakout with easyC with a Wemos D1 mini (ESP8266) powered via USB. Should I use the 5V pin or the 3.3V pin on the D1 mini for VCC on the easyC port? If the board is intended for 5V VCC, is it OK to power it directly from the D1 mini’s 5V (USB) while keeping I²C at 3.3V on SDA/SCL? Do I need to set the pull-up jumper to 3.3V (JP2) and leave 5V pull-ups (JP1) open? If 3.3V VCC is also supported, what current does the board require? Would powering it from the D1 mini’s 3.3V regulator be sufficient, or do you recommend a separate 3.3V supply? My intended wiring is: 5V (D1 mini) → VCC (sensor), GND ↔ GND, D2 (SDA) → SDA, D1 (SCL) → SCL. It would also help to know the typical heater current / total power consumption and any recommendations for decoupling when powered from USB.
Originally submitted via email support on 14 August 2025. Migrated to the forum for community visibility.
