How do I communicate with the MQ135 sensor via I2C and easyC interface? Which commands should I send, and is there demo code available?
Zanima me kako komunicirati sa MQ135 senzorom putem I2C odnosno easyC sučelja?(koje komande slati, postoji li nekakav demo kod?)
Hvala
Originally submitted via email support on 3 November 2023. Migrated to the forum for community visibility.
Here’s an example that should work with MQ135 using easyC: https://github.com/SolderedElectronics/Soldered-MQ-Gas-Sensor-Arduino-Library/blob/main/examples/easyC/MQ-135-ALL-easyC/MQ-135-ALL-easyC.ino
That repository is the library and you need to download and install it in documents/Arduino/Libraries. Here’s a more detailed tutorial: https://soldered.com/hr/learn/arduino-library/
evo primjera, trebalo bi raditi za MQ135 sa easyC-om: https://github.com/SolderedElectronics/Soldered-MQ-Gas-Sensor-Arduino-Library/blob/main/examples/easyC/MQ-135-ALL-easyC/MQ-135-ALL-easyC.ino
Taj repozitorij je biblioteka i potrebno ga je skinuti i instalirati u documents/Arduino/Libraries. Evo detaljnijeg tutoriala: https://soldered.com/hr/learn/arduino-library/
