MQ138 Gas Sensor Arduino library and example code
I didn’t find a .ino file for the MQ138 sensor. Can you provide one? I want to measure acetone level.
Originally submitted via email support on 15 August 2024. Migrated to the forum for community visibility.
The MQx library should work for this sensor in the same way: GitHub - SolderedElectronics/Soldered-MQ-Gas-Sensor-Arduino-Library: Library for all MQ sensor Soldered Boards. · GitHub
The MQ135 example should work just the same: Soldered-MQ-Gas-Sensor-Arduino-Library/examples/native/MQ-135/MQ-135.ino at main · SolderedElectronics/Soldered-MQ-Gas-Sensor-Arduino-Library · GitHub
The only uncertainty is the values you compare to - what the baseline voltage equivalent to PPM/PPB is for this specific sensor.
If this doesn’t work well, here’s an alternative found on GitHub: GitHub - Marta-Barea/arduino-MQ138-gas-sensor: Source code for MQ-138 gas sensor with Arduino UNO · GitHub
