I’m planning to use the NCV7329, but I can’t find any documentation, projects or software packages for it on your website.
Originally submitted via email support on 31 March 2026. Migrated to the forum for community visibility.
You can find an overview of the LIN transceiver and its hardware files at Welcome | Soldered Documentation
The transceiver expects UART data, which it internally converts into LIN format, so no external library is needed—you can just send UART to it. You could also check out the Arduino-LIN library and its examples: GitHub - Beirdo/Arduino-LIN: Arduino library to add dual LIN support on SAM3X and AVR based boards with a TJA1021/TJA1027 transceiver · GitHub
What I’m looking for are project examples or code to send LIN signals. The connection and wiring to the microcontroller is clear, but the specific functions to use to sync with the LIN or to send the specific signal are not clear.
This chip converts UART into a LIN signal and vice-versa. Code-wise it works the same as communicating between two microcontrollers using UART. You can change the baud rate as needed. If using Arduino, you can just call Serial.read() and Serial.write() to communicate. The library linked previously shows how the code looks and the functions involved.
You can also find the NCV7329 datasheet at https://www.onsemi.com/download/data-sheet/pdf/ncv7329-d.pdf
