Everything is working great. I have another question. I bought the NEMA17 Stepper Motor from you (Motori i upravljači | Hardver u pokretu – Soldered Electronics). The page lists 12VDC 350mm. Do you have detailed specifications for this specific motor? I’d like to increase the voltage to 24VDC and want to be sure it’s safe.
Sve radi od prve. Imam još jedno pitanje.
Kupio sam od vas
Na stranici piše 12VDC 350mm. Dali imate neke specifikacije ovog konkretnog motora?
Htio bi povisiti napon na 24VDC i zelim biti siguran.
Originally submitted via the contact form on soldered.com on 7 April 2025. Migrated to the forum for community visibility.
The motor should be able to handle up to 24V, but anything higher than that could be too much.
drago mi je da radi!
Motor bi trebao moći ići do 24V, više od toga može biti previše.
Can you please provide the exact specifications for the NEMA17 motor I purchased from you? I’m not satisfied with the power and would like to increase the voltage to 24VDC and the current to 1A. I’ve also sourced a TB6600 driver and don’t want to damage the motor.
Molim ako imate da mi napišete koji sam točno NEMA17 motor kupio od vas.
Nisam zadovoljan snagom i želio bi povećati napon na 24VDC i struju na 1A, nabavio sam i TB6600 i ne bi želio spržiti motor.
We use a generic NEMA17 component. You can find the datasheet here: https://pages.pbclinear.com/rs/909-BFY-775/images/Data-Sheet-Stepper-Motor-Support.pdf According to this datasheet, it can operate at 24V with 2A. 2A is the absolute maximum for both the driver and the stepper motor.
dobio sam informaciju da mi za NEMA17 uzimamo generičku komponentu, možete ovdje pogledati datasheet: https://pages.pbclinear.com/rs/909-BFY-775/images/Data-Sheet-Stepper-Motor-Support.pdf
Prema ovom, izgleda da se može koristiti 24V i 2A, 2A je apsolutni maksimum i za driver i za taj step motor.
