I bought 2 NRF24L01 adapters for Dasduino but I didn’t find an Arduino / Dasduino board which fits to the NRF24L01 adapter. Which Arduino / Dasduino board types are compatible with this adapter?
Originally submitted via email support on 4 December 2025. Migrated to the forum for community visibility.
The NRF adapter works with both the Dasduino CONNECT and Dasduino CORE boards. The pins on the left side of each board match the pins required by the NRF adapter.
Dasduino CONNECT pinout: https://soldered.com/productdata/2022/06/Dasduino-CONNECT.png
Dasduino CORE pinout: https://soldered.com/productdata/2022/04/Dasduino-CORE-ATmega328-Pinout.png
Is there a recommendation for a library I need for programming Dasduino Core with Arduino IDE?
You can use Arduino IDE with the Dasduino CORE board definition. Check the Dasduino Board Definitions for Arduino IDE repository: GitHub - SolderedElectronics/Dasduino-Board-Definitions-for-Arduino-IDE · GitHub
This is all you need for Dasduino CORE. Here’s the quick start guide: Arduino - Arduino Quick Start Guide | Soldered Documentation
