nRF24L01 for long-range indoor wireless communication
I’m a student at an electrotechnical school working on a project and I’m interested in alternatives to a 433 MHz remote control and receiver that can work over longer distances indoors, for example 50-100 meters. Additional power supply up to 9V is not a problem.
Original message (Serbian)
Ucenik sam Elektrotehnicke skole Zagreb, radim na projektu pa me zanima da li imate mozda koju alternativu za 433MHz daljinski i receiver, a da radi na malo vecu udaljenost unutar prostorija npr 50-100 metara. Dodatno napajanje do 9V nije problem.
Ako hocete mogu napraviti zahtjev u ime svoje skole. Hvala!
Originally submitted via email support on 19 March 2023. Migrated to the forum for community visibility.
We have the nRF24L01 and an adapter for it if you’re using Dasduino boards. This is a module often used for wireless communication that operates at 2.4 GHz. The module itself is a transceiver, so you can use it as both a receiver and transmitter. We also have a version with an antenna that can achieve a range of over 1 km. It’s also very simple to use.
Imamo NRF24L01 te adapter za njega ako ćete koristiti Dasduino pločice. To je modul koji se često koristi za bežičnu komunikaciju, radi na 2.4 Ghz, a sam modul je primporedajnik tako da ga možete koristiti kao primjenik i odašiljač. Također imamo i verziju sa antenom sa kojom je moguće postići nešto preko 1 km dometa. Također je jako jednostavan za korištenje, evo jedan jednostavan primjer.
