I have three questions:
Where can I find the UF2 file for this board to program it in MicroPython?
Is there any compatibility between your board and the SparkFun board at Introduction - SparkFun IoT RedBoard - RP2350 Hookup Guide?
Can I follow the tutorials at https://sik.sparkfun.com/ with your board?
1.) gdje mogu naći UF2 file za ovu pločicu da bi je mogao programirati u Micropythonu?
2.) postoji li nekakva kompatibilnost između vaše pločice i ove od tvrtke Sparkfun?
3.) Mogu li s vašom pločicom sljediti tutoriale na stranici:
Srdačno
Originally submitted via email support on 11 March 2026. Migrated to the forum for community visibility.
Regarding your questions:
The UF2 files for this board are currently being published to the official MicroPython pages. I will send you the UF2 file separately.
Yes, our board supports all the features that the SparkFun IoT board has, plus an additional HDMI connector.
Looking at the content of the tutorial you linked, you can follow it without code changes. If you need help during implementation, feel free to reach out.
Isprike na kasnom odgovoru, u vezi Vaših pitanja:
Trenutno smo još u procesu objavljivanja UF2 datoteka za ovu pločicu na službenim MicroPython stranicama, naknadno ću vam poslati UF2 file u ponedjeljak, dotada ostavljam ovaj ticket otvoren Da, naša pločica podržava sve značajke koje Sparkfun IotBoard ima s još dodatnim HDMI konektorom Gledajući po sadržaju tutorijala koji je priložen, moguće ga je slijediti bez izmjene koda, ukoliko bude potrebna pomoć pri izradi slobodno nam se javite.
I am sending the .uf2 file containing the MicroPython firmware for the Soldered NULA Max RP2350.
U prilogu šaljem .uf2 datoteku micropython firmwarea za Soldered NULA Max RP2350
Attachment omitted in migration: rp2350_firmware.uf2
I don’t see the attached file.
Jutro. Ne vidim priloženi file Lp [name removed]
I apologize. Gmail may be blocking .uf2 files. You can download the uf2 file at LimeWire: Share Files - Secure File Upload Platform for the next week.
Ispričavam se, moguće da Vam gmail blokira slanje .uf2 datoteka, u slijedećem linku možete preuzeti uf2 datoteku u idućih tjedan dana: LimeWire: Share Files - Secure File Upload Platform
