PCF85063A crystal load capacitance and component specifications
I didn’t find the details for the crystal in the design files. How much capacitance did you choose there?
It would be better to have the details of which part was assembled on the board directly on the schematic or the BOM files. Then I wouldn’t need to ask, and you wouldn’t need to answer.
Originally submitted via email support on 11 September 2025. Migrated to the forum for community visibility.
Due to sourcing differences we opted to use several different crystals. If you take a detailed picture of the one you have, I can exactly specify which one it is per the datasheet. These are the three possibilities:
Crystal Model Doc Load Capacitance (CL) Shunt Capacitance (C0) Motional Capacitance (C1)
C5361379 C5361379.pdf 12.5 pF 0.9 pF (typ.) 3.7 fF (typ.)
C271654 C271654.pdf 12.5 pF 1.1 pF 4.1 fF
C479190 C479190.pdf 12.5 pF (or specify) 1.0 pF (typ.) 3.4 fF (typ.)
All three are SMD3215 footprint. The models are SMD3215 (JingGuangHua), SF-3215 (TKD), and 3215 (JingGuangHua alt.) respectively.
