This sensor is actually a switch designed for measuring liquid level.
The switching (activation and deactivation of signal) works using a magnetic reed switch located inside a plastic tube. Inside the tube is a float containing a magnet that moves up and down depending on the liquid level. When the float reaches a certain point, the magnet activates the reed switch, which can then close (activate) or open (deactivate) the circuit.
According to the specifications below, yes, it can tolerate 220V, but keep in mind that because the contact is mechanical and brief impulses can occur during switch activation and deactivation, your load must be able to tolerate this switching behavior. Personally, I would connect the switch to a Dasduino and use a relay as the final switch for the load.
P52 liquid level sensor specifications:
- maximum contact power: 10W
- maximum switching voltage: 110V
- maximum switching current: 0.5A
- maximum breakdown voltage: 220VDC
- maximum contact resistance: 100mΩ
- maximum operating pressure: 1Mpa
- cable length: 40 cm
- weight: 16 g
- operating temperature: -10°C to +60°C
- float material: PP (polypropylene)
- housing material: PP (polipropylene)
hvala na upitu! Ovaj senzor je u stvari prekidač, dizajniran za mjerenje razine tekućine.
Preklapanje, odnosno uključivanje i isključivanje signala, kod ovog senzora odvija se pomoću magnetskog reed prekidača smještenog unutar plastične cijevi. U toj cijevi nalazi se plovak koji sadrži magnet, a on se pomiče gore-dolje ovisno o razini tekućine. Kada plovak dosegne određenu točku, magnet aktivira reed prekidač, koji tada može zatvoriti (uključiti) ili otvoriti (isključiti) strujni krug.
I prema specifikacijama koje su niže, da, može tolerirati 220V ali imajte na umu da zbog toga što je kontakt mehanički i mogu postojati kratkotrajni impulsi pri uključivanju i isključivanju prekidača, vaše trošilo mora moći tolerirati uključivanje i isključivanje na ovakav način. Osobo, ja bi spojio prekidač na Dasduino i koristio relej kao konačnu sklopku za trošilo.
Specifikacije P52 senzora razine tekućine:
maksimalna snaga kontakta: 10W maksimalni napon uključivanja/isključivanja: 110V maksimalna struja uključivanja/isključivanja: 0.5A maksimalni probojni napon: 220VDC maksimalni otpor kontakta: 100mΩ maksimalni radni tlak: 1Mpa duljina kabela: 40 cm težina: 16 g radna temperatura: -10°C do +60°C materijal plovka: PP (polipropilen) materijal kućišta: PP (polipropilen)
Nadam se da to pomaže s projektom!
