I found the PM2.5 air particle sensor PMS5003. Do you have any instructions, in Croatian or English, on how to connect it to Croduino?
Sad sam video ovaj senzor,
Senzor čestica zraka PM2.5 PMS5003
Da li imate neka uputstva, bilo na hrvatskom ili na engleskom kako da spojim na Croduino?
Originally submitted via email support on 30 August 2018. Migrated to the forum for community visibility.
You can find information about using this sensor at: Overview | PM2.5 Air Quality Sensor | Adafruit Learning System
ovdje možeš pronaći info o korištenju senzora: Overview | PM2.5 Air Quality Sensor | Adafruit Learning System
Can it be connected directly to Croduino?
Jel moze direktno da se prikljuci na Croduino?
Yes, of course, exactly as in the tutorial.
Da, naravno, baš kao u tutorijalu
The only thing is that in the tutorial there’s a breakout board for connection, but you’ll need to connect it to Croduino with wires. Everything else remains the same.
Jedino što u tutorijalu postoji breakout board za spajanje, a ti ćeš morati kablićima povezati s Croduinom. Sve ostalo ostaje isto.
I also have a temperature sensor with a cable. Is there a tutorial for it?
Odlicno.
Samo jos jedno pitanje, uzeo sam merac temperature sa kablom, jel ima neki tutorial
Which temperature sensor exactly are you asking about?
O kojem točno senzoru temperature se radi?
The water one with a cable.
Onaj za vodu sa kablom
