Proto:bit EasyC connectors and I2C communication with BBC micro:bit
I purchased a proto:bit for BBC micro:bit. I couldn’t find any example on your website for using EasyC. Is there an extension for Makecode?
Poštovani, kupili smo proto:bit za BBC microbit. Nisam pronašao na Vašoj stranici primjer korištenja Easyc. Da li postoji extenzija za Makecode?
Originally submitted via email support on 7 August 2022. Migrated to the forum for community visibility.
easyC is our standard for I2C communication and is nothing more than a connector and wire arrangement. You can read more about it at Soldered: Open-Source Electronics, Boards, Sensors & Modules – Soldered Electronics.
Can you explain what you’re trying to do so we can help you better? If you’re wondering whether there’s a direct easyC extension for Makecode, unfortunately the answer is no.
easyC je naš standard za I2C komunikaciju, te nije ništa više od konektora i rasporeda žica. Možete si pročitati više o njima na Soldered: Open-Source Electronics, Boards, Sensors & Modules – Soldered Electronics.
Možete li objasniti što radite kako bi Vam mogli bolje pomoći, ako mislite postoji li direktna ekstenzija za easyC za Makecode onda je nažalost odgovor ne.
The proto:bit has 2 EasyC connectors on it. Please provide some example of how to use them in any language or a link to a library. What’s the point of having EasyC connectors on the proto:bit if I can’t control them programmatically?
Na proto:bitu nalazi se 2 komada EasyC konektora. Molim Vas neki primjer korištenja u bilo kojem jeziku ili link na neku biblioteku. Čemu onda na proto:bitu EasyC konektori ako ih ne mogu programski uptavljati?
The easyC connector is used for I2C communication. Instead of connecting 4 separate wires which are needed for I2C communication, we use this connector to make I2C communication easier. So you can use any library from sensors or actuators that use I2C communication. Try reading the tutorials at MICRO:BIT and I2C LCD example and Connecting I2C Devices to the BBC micro:bit – smalldevices.
easyC konektor služi za I2C komunikaciju te umjesto da spajate 4 odvojene žice koje su potrebne za I2C komunikaciju, mi koristimo taj konektor da nam olakša korištenje I2C komunikacije. Dakle možete koristi bilo koju biblioteku od npr. senzora, aktuatora koji koristi I2C komunikaciju. Probajte pročitati tutorial na MICRO:BIT and I2C LCD example i Connecting I2C Devices to the BBC micro:bit – smalldevices.
