Raspberry Pi GPIO Cable pin count and soldering options
Is the Raspberry Pi GPIO cable a 40-pin connector? Do you have any connectors compatible with it that allow easy soldering or connection to it?
Je li GPIO kabel za Raspberry Pi (Soldered: Open-Source Electronics, Boards, Sensors & Modules – Soldered Electronics) sa 40 pinova? I imate li neki konektor koji je kompatibilan sa njim, a da je moguće isti jednostavno dalje lemiti (tj. spajati se na njega)?
Originally submitted via email support on 25 January 2019. Migrated to the forum for community visibility.
Yes, the cable has 40 pins for the RPi 3.
Unfortunately we don’t have anything for direct soldering. The options are to get a breakout for a breadboard: https://e-radionica.com/hr/raspberrypi-gpio-breakout-t-oblik.html
or some cables (for example with a female end, then cut one end and solder to it): Set kablića žensko-ženski, 40 komada – Soldered Electronics
da, kabel je s 40 pinova, za RPi 3.
Nažalost nemamo nešto za direktno lemljenje. Opcije su uzeti breakout za eksperimentalnu pločicu: https://e-radionica.com/hr/raspberrypi-gpio-breakout-t-oblik.html
ili nekakave kabliće (recimo s ženkim krajem pa odrezati jedan kraj i na njega lemiti): Set kablića žensko-ženski, 40 komada – Soldered Electronics
Javite ako još kako možemo pomoći.
What is the cable length?
Kolika je duljina kabela?
The cable length is approximately 22 cm.
duljina kabela je oko 22cm.
