Relay Module compatibility with Raspberry Pi 3.3V output
I need information about this relay module. Will it work with Raspberry Pi since it outputs 3.3V on the pins? If not, do you have a relay module in your offer that works with Raspberry Pi?
Treba mi informacija o ovom releju: https://e-radionica.com/hr/er-relej1.html Hoće li raditi sa Raspberry Pi budući da on na pinovima šalje 3.3V?
Originally submitted via email support on 10 March 2020. Migrated to the forum for community visibility.
The relay module you mentioned operates at 5V. We don’t have one that would activate at 3.3V. You can try stepping up the voltage from 3.3V to 5V using a logic level converter: Soldered: Open-Source Electronics, Boards, Sensors & Modules – Soldered Electronics
hvala Vam na upitu. Modul s relejem koji ste naveli radi na 5V. Možete pokušati podizanjem napona s 3.3V na 5V pomoću: Soldered: Open-Source Electronics, Boards, Sensors & Modules – Soldered Electronics
