I recently purchased the NULA Max RP2350 and I am currently designing a custom 3D-printed enclosure for it.
Since the public hardware repository is not yet fully published, could you please provide the mechanical drawing (with hole spacing and port offsets) or the 3D STEP model of the board?
The hardware repo link is the right starting point, but check whether it actually includes the STEP export or only schematics and layout files. On several RP2350 boards the published mechanical data lags behind the electrical docs, so if the STEP isn’t there yet, the drawing with mounting-hole spacing and port offsets is usually what enclosure designers need most. For a first draft you could also measure the board yourself and leave clearance around the USB and antenna areas, then adjust once official models are posted.
