RFID reader options and components
I need information about RFID card readers.
Molim vas da mi pošaljete podatke za čitać RFID kartica.
Hvala lijepa Pave
Originally submitted via email support on 22 January 2019. Migrated to the forum for community visibility.
Which reader are you interested in information about?
za koji čitač Vas zanimaju info?
Unfortunately, we don’t have a ready-made system for this, only components for building one.
nažalost nemamo takav gotovi sustav, nego samo komponente za njegovu izradu.
This is our RFID reader category. We have two models with the difference in frequency: one operates at 13.56MHz and the other at 125kHz. Both readers can only read from tags. If you need to write as well, you must use the PN532 NFC and RFID controller. You can find all information on each product’s page, including the datasheet.
ovo je naša kategorija RFID čitača: https://e-radionica.com/hr/komunikacija/rfid-nfc.html
zapravo dva koja imamo, razlika je u frekvenciji
ovaj nam radi na 13.56MHz: https://e-radionica.com/hr/rfid-citac-mfrc-522-s-rfid-karticom.html
dok je ovaj na 125kHz: https://e-radionica.com/hr/rfid-citac-rdm6300-125khz.html
Ta dva čitača mogu samo čitati sa tagova. Ako trebate i pisati, morate koristiti ovo: https://e-radionica.com/hr/pn532-nfc-i-rfid-kontroler-2x-tag.html
Na stranici svakog od proizvoda možete pronaći sve informacije, ukljućujući i datasheet.
Ako imate još pitanja, slobodno nam javite.
For that use case, you need the 125kHz RFID reader sensor, a microcontroller board, and LEDs.
u tom slučaju Vam je potreban senzor: https://e-radionica.com/hr/rfid-citac-rdm6300-125khz.html
Ova pločica: Soldered: Open-Source Electronics, Boards, Sensors & Modules – Soldered Electronics
Te LEDice: Paket 5mm LED dioda (13 komada) – Soldered Electronics
