RGB IR LED Controller control box connector type
I found the RGB IR LED Controller (SKU108241) in your web shop. I need to know what type of connector is on the control box - is it male or female?
U Vašem web shpu sam naišao na artikl RGB IR LED KONTROLER (SKU108241).
Zanima me da li kakav je izlaz na kontrol boxu, muški ili ženski ? (da li ima rupice ili one male pipke što vire van)
Originally submitted via email support on 16 October 2018. Migrated to the forum for community visibility.
The connector is female. A small header is included that converts it to male, which can also be removed if you need it to be female again.
izlaz je ženski, a dolazi mali header koji ga pretvara u muškoga, koji se također može izvaditi pa postaje opet ženski.
