I’m studying Arduino and how it could help us. I overlooked the need for an RS232 to TTL converter like the one in the image I’m attaching. Can you tell me if you can supply this or a similar module? If so, I would definitely place an order.
intenzivno proučavam priču oko arduina i kako bi nam mogao pomoći pa sam eto malo previdio priču oko nabavke RS232 na TTL konvertera kao na slici u prilogu. Možete li mi javiti da li možete nabaviti ovakav ili sličan modul i ako da, svakako bi naručio. Hvala unaprijed, [name removed], dipl.ing.el. EKONERG - Institut za energetiku i zaštitu okoliša d.o.o. Odjel za mjerenja i analitiku - Laboratoriji EKONERG - Energy and Environmental Protection Institute Department for Measurement and Analytics - Laboratories Koranska 5, Zagreb HR-10000, Croatia http://www.ekonerg-laboratorij.com Tel. [phone removed] Fax. [phone removed] Mob. [email removed]
Attachment omitted in migration: rs232_ttl.jpg
Originally submitted via the contact form on soldered.com on 15 February 2018. Migrated to the forum for community visibility.
I’m looking into this now and I can’t believe we don’t have RS232 in our range either - we only have RS485. Unfortunately, we can’t help with something faster than that. How quickly do you need the module?
Tako da, nažalost, ne možemo pomoći s nečime brzime. Koliko brzo trebate modul?
By the end of the month would be good. I’ll start experimenting with analog inputs and PWM first. I’d take at least 5 pieces, and potentially more later if it works out. What do you have in RS485? That’s interesting to me because I have some devices that work over it too.
Pa recimo do kraja mjeseca…prvo ću se poigrati s analognim ulazima i pwm-om . uzeo bih najmanje 5 komada, a kasnije još ako.stvar proradi. Što imate od rs485?i to mi je interesantno jer imam neke uređaje i preko njega…
[name removed], dipl.ing.el. Ekonerg d.o.o., Koranska 5,[address removed]
Unfortunately we won’t be able to source it by the end of the month. For RS485, we have the classic module with MAX485: Soldered: Open-Source Electronics, Boards, Sensors & Modules – Soldered Electronics
nažalost od kraja mjeseca nećemo stići pribaviti.
RS485 imamo klasika modul s MAX485: Soldered: Open-Source Electronics, Boards, Sensors & Modules – Soldered Electronics
