Can I connect the RTC using standard cables like those on Arduino, or must I use an easyC connector?
Pozdrav, zanima me moram li se na RTC spajati preko easy c konektora ili to mogu raditi sa standardnim kablićima kao što su na Arduinu?
Originally submitted via email support on 25 September 2023. Migrated to the forum for community visibility.
The RTC breakout can be connected not only via easyC connector but also via standard cables - the pins are available on the board. EasyC carries I2C communication, which is available both on the easyC connector and on the SCL/SDA pins (along with VCC/GND). Connecting it that way is equivalent to connecting it with an easyC cable.
naš RTC breakout (na ovom linku, čisto da budem siguran da pričamo o istom proizvodu) PCF85063A RTC Real-Time Clock Module with Battery Backup & Alarm – Soldered Electronics se može spajati ne samo preko easyC konektora već i preko običnih kablića, pinovi su dostupni na boardu. EasyC prenosi I2C komunikaciju i ona je, ne samo na easyC konektorima već i na SCL/SDA pinovima (uz VCC/GND). Ako ga spojiš tako, to je isto kao da si ga spojio s easyC kablom.
