SGX-OX-ROHS-LP custom sensor type configuration
I’m trying to use an oxygen sensor from SGX with the Arduino library. I need to create a custom sensor type but cannot find the necessary information in the datasheets. How do I configure the sensorType struct for this sensor?
Originally submitted via email support on 25 September 2025. Migrated to the forum for community visibility.
Here’s the sensor type configuration for the SGX-OX-ROHS-LP oxygen sensor:
const sensorType SENSOR_OX = {
 5.0F, // nanoAmperesPerPPM (approx, based on 0.1 mA in air -> ~4760 nA per %vol; ≈ 4.76 nA/ppm)
 0.0, // internalZeroCalibration (oxygen has small offset; can be tuned after calibration)
 ADS_GAIN_2_048V, // adsGain (keeps sensor output within ADC range)
 TIA_GAIN_120_KOHM, // TIA_GAIN_IN_KOHMS (balances sensitivity vs noise)
 RLOAD_10_OHM, // RLOAD (common for SGX sensors)
 REF_EXTERNAL, // REF_SOURCE (external 2.5V reference)
 INTERNAL_ZERO_67_PERCENT, // INTERNAL_ZERO (best bias point for -600 mV)
 BIAS_SIGN_NEGATIVE, // BIAS_SIGN (datasheet specifies -600 mV)
 BIAS_24_PERCENT, // BIAS (≈ -600 mV with 2.5V ref → 0.24 * 2.5V ≈ 0.6 V)
 FET_SHORT_DISABLED, // FET_SHORT
 OP_MODE_3LEAD_AMP_CELL, // OP_MODE
This is based on the datasheet specifications for this oxygen sensor.
Attachment omitted in migration: ds-0549-sgx-ox-rohs-lp.pdf
