I’m using your sensor for my project. I need information about the resistor that is built into the voltage divider along with the photoresistor.
za potrebe svog projekta koristim vaš senzor
Jednostavan senzor svjetla Pločica za elektroničke projekte – Soldered Electronics
Molim vas podatak o otporniku koji je ugrađen u naponsko djelilo zajedno s foto otpornikom.
Originally submitted via email support on 26 April 2022. Migrated to the forum for community visibility.
The voltage divider contains a 10kOhm resistor connected to the VCC pin and to the analog output. The photoresistor is connected to the analog pin and to GND, forming a voltage divider with this 10kOhm resistor. A schematic of the sensor is attached to show how everything is connected.
U naponskom djelilu je ugrađen otpornik od 10kOhma koji je spojen na VCC pin i na analogni izlaz. Fotootpornik je spojen na Analogni pin i na GND te tako s ovim otpornikom od 10kOhma čini naponsko djelilo. U prilogu je shema senzora iz koje je lakše shvatiti što je kako spojeno.
Attachment omitted in migration: Simple_sensor_Light.pdf
