Can you tell me if the wire in SKU 100862 (Set of cables for breadboard, 65 pieces) is the same as the male connector in SKU 100865 (Set of male-female cables, 40 pieces)? I need male-male cables like SKU 100865 but I’m not sure if SKU 100862 is the same type.
Originally submitted via email support on 26 August 2020. Migrated to the forum for community visibility.
The only male-male cables in the current offer is SKU 100862. Comparing with SKU 100865, they are not the same type of cables.
I want to buy male-male jumper wires but need to verify if the male pin in the breadboard wires is the same size as the male pin in the male-female cables, as they look different in the pictures. The black plastic connector appearance doesn’t matter to me, but I need the same kind of male pins as in the male-female wire. You advertise the breadboard cables as being for the breadboard and not as male-male jumper wires. Is there a difference? Since I’m a beginner, I don’t know much about this but need to know before making a purchase.
The male/female connector sizes are not the same, but they fit each other and can be connected with each other. There is no difference between breadboard cables and male-male jumper wires—they will all fit together. The male-male jumper wires are actually this product: Set of Cables for Breadboard, 65 Pieces – Soldered Electronics, just named differently.
