Smart RGB LED strip WS2812 connector options for 60LED/M 5V IP20
What connector should I use to connect the Smart RGB LED strip WS2812 60LED/M 5V IP20?
Da li mi možete preporučiti koji/kakav konektor bi se trebao koristiti za spajanje „Pametna RGB traka WS2812 60LED/M 5V IP20“?
Hvala vam unaprijed. LP,
From: [name removed] (Generalni kontakt: e-radionica.com) [mailto:[email removed]]
Sent: Wednesday, October 04, 2017 12:15 PM
To: [name removed]
Originally submitted via the contact form on soldered.com on 10 October 2017. Migrated to the forum for community visibility.
The strip requires solder connections to:
  • +5V
  • GND
  • DATA - signal from the microcontroller
If your strip already has a connector, there would be a matching one available. We don’t have it in stock, but I have one here and can send it to you if needed.
na navedenu traku konektor se lemi:
+5V
gnd
DATA - signal s mikrokontrolera
Ako već imate konektor na njoj, onda postoji i odgovarajući za njega. Nemamo ga u prodaji, ali imam ovdje jedan pa Vam mogu poslati - samo javite jel treba, ne znam imate li konektor na svom komadu trake.
The LED strip doesn’t have a connector, so if you could send one I would be happy to pay for it.
Hvala vam za info. Na LED traci nema konektora, pa ako vam nije problem možete mi poslati (platim ga pri preuzimanju).
Hvala još jednom. LP,
If you don’t have a connector, a second one won’t help much. It’s best to solder wire directly to the connection points I mentioned in my previous message and connect it to the microcontroller. Do you have a soldering iron? You’ll need to solder the connector anyway.
ako nemate jedan konektor, neće puno pomoći drugi. Najbolje onda da zalemite žicu na mjesta koja sam napisao u prošlom emailu i spojite na mikrokontroler. Imate lemilicu? Konektor biste također trebali zalemiti..
